Modifications importantes sur la camaro - ATTENTION
Unknown
Message par Unknown »
Petit retour d'expérience d'Américains (hot rod mag) sur les limites de la camaro lorsqu'on y modifie pas mal de chose de façon lourde
http://www.hotrod.com/techarticles/gene ... ewall.html
Introduced in April 2009 as a '10 model, the fifth-gen Camaro is the newest entrant in the Big Three's renewed ponycar wars. Despite the car's late start, loyalists aren't taking a back seat to anyone; they've been beating on the cars, finding what goes wrong, and applying good old hot rodding engineuity to fixing the issues while giving the other guys a run for their money. Still, the new chassis remains a work in progress. Expect big improvements in the top driveline offerings for '12, but in the meantime, here's the scoop on the cars as they are now configured. Our consultants include hard-core Camaro specialists Lingenfelter Performance Engineering (LPE), Livernois Motorsports, IPS Motorsports, the School of Automotive Machinists (SAM), and other insiders. All quoted power levels except for the stock factory ratings are at the rear wheels. Remember, there is at least a 15 percent loss through the drivetrain with a manual trans, up to 20 percent with an automatic.
Engine
Fifth Gen Camaro Parts Failure Capital achievement: As of late 2010, Lingenfelter’s stout ’10 Camaro has run a best quart
6.2L (376CI) LS3 (Manual Trans)
The LS3 is factory rated at 426 hp and 420 lb-ft of torque for manual trans cars. Currently this is the preferred combo for serious performance upgrades, as it does not have variable camshaft timing (VCT) or active fuel management (AFM or cylinder deactivation).
Lifter pump-up (7,000-plus rpm): Replace with short-travel Comp Cams lifters, which require either adjustable rockers or carefully selected pushrod lengths.
Timing chain tensioner fails (550 hp): Install a Comp or JP Performance billet timing set.
Oiling needs help (road-racing or stroker engines): LS engine oil pumps bypass too much oil, plus poor oil drain-back and foaming is a serious problem over 6,500 rpm. Go to a modified aftermarket oiling system and pan. For road racing, consider an ARE dry-sump.
Fifth Gen Camaro Parts Failure Can’t spin this one: Don’t expect the stock balancer to last at high rpm or with big strok
Rods break (600 hp): Stock powdered-metal rods may break at the beam. Use forged rods.
Head gasket problems (600 hp): Upgrade to aftermarket MLS gaskets and ARP fasteners.
Pistons fail (600-625 hp, detonation and/or excessive boost): Replace the stock hypereutectics with forged pistons.
Crank good to go (900-plus horsepower): LPE turbo engines make more than 900 hp on stock nodular iron cranks.
Exhaust valves (over 10 psi boost): At this point, LPE swaps the stock LS3 exhaust valves with more durable Inconel or sodium-filled ones.
Fuel system upgrade (various): Install larger injectors at 450 to 475 hp. For over 6 psi boost or 500 hp, use a voltage booster. Upgrade the stock pulse-width-modulated nonreturn fuel pump at 575 to 620 hp. Livernois and LPE have dual-pump systems adequate through 750 to 800 hp. Beyond that use dual or triple high-capacity pumps and a return-style fuel system.
Fifth Gen Camaro Parts Failure Lost its bearings: Pushrod deflection from big cams and increased spring pressures causes
6.2L (376 CI) L99 (Auto Trans)
The 400hp/410-lb-ft L99 is used in V8 Camaros with an automatic. With both VCT and AFM, it's harder to modify in stock form. Short-block problems are similar to the LS3.
AFM problems (450 hp, 0.500-inch-lift cams, or high rpm): Half the lifters and their corresponding cam lobes are unique. Comp and LPE offer AFM-style cams, but they're limited to 0.500-lift because the special lifters don't work with a reduced base circle. If you raise the rev limiter beyond the L99's 6,200-rpm limit and then run up against it, Jannetty Racing says the AFM lifters will fail. Best option: Reprogram the ECU to delete AFM, then install a conventional cam and lifters.
VCT phaser woes: Valve-to-piston contact can occur with bigger cams from too much advance. Comp Cams has a phaser limit kit that allows aggressive cam profiles with up to 220 degrees duration at 0.050. Above this, either: increase intake centerline 2 degrees for every 4-degree duration increase, change pistons, or delete VCT; the latter requires installing a LS3 front cover and a conventional timing set.
Valve float: L99s don't have the LS3's hollow-stem intake valves. When switching to high-lift cams, LPE recommends installing lighter LS3 intake valves.
Transmission
Fifth Gen Camaro Parts Failure Break-fast: The mainshaft on about 10 percent of TR-6060-equipped Camaros produced within
6L80 Six-Speed Automatic
This new-gen GM trans is so sophisticated that it has a separate computer (TCM or transmission control module). Incorrect TCM tuning causes more problems than hard-parts failures.
TCM calibration: Reprogramming is required when changing engine rpm range, shift points, or rearend gear ratio. A significant power change increases engine acceleration rate, which changes the amount of trans slip; both impact when the shift needs to occur compared with when the TCM calculates it should occur. HPTuners has reprogramming software.
TAPshift lag: When enabled, on-demand manual gear changes are made via steering wheel paddles. TAPshift permits holding a specific gear around a road course without fear that the trans might upshift or downshift during a turn and destabilize the car. It also works well for a burnout, but input lag creates straight-line acceleration issues; for drag racing, reprogram to upshift automatically at a desired shift rpm.
Torque management damage: Disabling torque management completely can cause failures. LPE says, "With a clutch-to-clutch trans like the 6L80, some torque management is needed to reduce the torque momentarily and allow time for the clutch for the desired gear to engage."
Torque converter (500-plus horsepower): LPE reports zero failures, IPS is confident through 500 hp, and Livernois says it has "a stock converter in a '10 Camaro that makes over 750 hp with close to 100 quarter-mile runs along with street driving." Precision Industries, TCI, Yank, and others sell high-stall converters. A triple-disc converter and custom trans tuning will ensure the converter stays locked up in Overdrive even on high-power mills.
Fifth Gen Camaro Parts Failure Tooth decay: Missed shifts can damage synchro blocker rings and the main-gear clutch-engag
Hard-parts failures (over 575 hp): With correct programming, Livernois and others report minimal internal hard-parts failures through 575 to 600 hp. Rossler builds beefed 6L80s. It says the 3-5 reverse clutch usually fails first, followed by the 4-5-6 clutch: "We add more clutches, machine special steels, and use better materials." Fully built Rossler 6L80s have withstood 1,000 hp on a chassis dyno; 750 hp is more realistic for long-term street durability.
TTC TR-6060 Six-Speed Manual
Like stick-shift Dodges and Shelby Mustangs, V8 Camaros use TTC TR-6060 six-speeds. Enabling GM's launch control feature can minimize the chances of trans or rearend failure. RPM Transmissions' fully blueprinted Level 6 TR-6060 can handle more than 1,000 hp.
Mainshaft breaks (random): On some early production '10 Camaros, the mainshaft can fail ahead of the output splines due to an overly large machining radius. Although 475 hp is probably the critical risk point, RPM says it can sometimes "fail bone stock, even with factory-original tires." GM's fix is a redesigned chamfer, improved metallurgy, and a different heat treat. The new 'shaft can be retrofitted, but that requires a complete teardown. Reference GM service bulletin PIP4666.
Rear support bearing upgrade (650-680 hp): Unlike some other TR-6060s, the Camaro version lacks a rear support bearing. The Camaro extension housing is machined for the bearing, but it is not factory installed. Livernois advises adding the bearing over 650 hp. The bearing, plus an improved 9310-steel mainshaft machined for it, is sold as a kit from RPM Transmissions and The Driveshaft Shop.
Synchro blocker ring (525 to 625 hp and/or abuse): Early production has brass rings, while later has carbonized rings. Carbon is more forgiving, but brass rings are stronger if you're a hot shoe.
Clutch problems (600 hp): Although SAM maintains that "bone-stock power will take the clutch out running on sticky tires—even a drag radial," most other sources say serious clutch problems start around the 600hp to 650hp level. Upgrade as appropriate to aftermarket clutches. LPE runs a triple-disc RPS carbon clutch in its 1,240hp drag car.
Hydraulic clutch actuation issues: IPS has seen soft clutch engagement and difficulty getting the car in gear after multiple dragstrip passes. Apparently heat buildup causes a clutch fluid viscosity breakdown. Bleed the system often and use a higher-quality clutch fluid.
IRS and Driveshaft
Fifth Gen Camaro Parts Failure Kicked in the ass: On its third dragstrip launch running Hoosier slicks, this aftermarket
The V8 Camaro's IRS (independent rear suspension) has 218mm (8.58-inch) rear gears and a clutch-type limited-slip diff. The gears are unique. Stock ratios are 3.27 or 3.45:1; Richmond has 3.70 and 4.10:1 ratios. The current stock rear is marginal for serious high-perf use.
Rear suspension flex (450 hp): IPS reports toe-arm failures as low as 25 to 50 hp over stock. Pfadt has stiffeners; BMR offers adjustable units. Excessive wheelhop can damage the rear trailing arms, contributing to differential problems (Pfadt and LPE have upgrades). Hotchkis sells a Chassis Max Brace to control unwanted suspension movement.
Rear subframe flex (475 hp): The stock subframe bushings allow excess cradle movement, causing lost power and bad traction. Replace with solid or polyurethane bushings for better rear-cradle durability and improved handling. Pfadt is one source.
Gears fail (500-plus horsepower): Only a three-series Posi carrier is available, so the pinion gets really small as gear ratio increases. Tire type and driving style influence longevity big time.
Halfshafts break (wheelhop, 500 to 600 hp): The more severe the wheelhop, the sooner the drive axles break. The stock computer calibration limits axlehop, but that also limits performance. Knowing when to back off the throttle is the cheap fix, followed by lighter-weight wheels and tires (because they have less inertia), and ultimately stouter aftermarket axles.
Posi problems (various): Jannetty says the stock Posi is weak: "It's prone to one-legger burnouts; the breakaway torque is way too low." Its Posi mods include upgraded clutch packs and a different preload spring. With a tuned Posi and revised internal gear preload, clearances, and patterns, the stock rear can take up to 750 hp, but 650 hp is more realistic for daily driving.
Driveshaft issues (over 5,000 rpm): Most report that the stock two-piece driveshaft is surprisingly robust. LPE's 9-second Camaro uses a shortened, stock, two-piece 'shaft, but with an improved center support to prevent the middle slider from twisting and binding. However, The Driveshaft Shop maintains that "anything with a slider is unstable over 5,000-rpm driveshaft speed." Its solutions range from a stouter two-piece unit with a CV joint or a one-piece aluminum or carbon-fiber 'shaft.
Read more: http://www.hotrod.com/techarticles/gene ... z2uHgnd7q0
Re: Modifications importantes sur la camaro - ATTENTION
wow, super, les infos !
merci Wolf
Unknown
Je pense qu'ils savent de quoi ils parlent question modifications des muscle cars et autres véhicules hot rod.
NB: si quelqu'un veut faire la traduction de ce texte pour les camaristes ici qui sont pas amis avec l'anglais...
johnkeats
Modele : Camaro EU 2012 blanche bandes noires
Message par johnkeats »
Rocket Raccoon a écrit : NB: si quelqu'un veut faire la traduction de ce texte pour les camaristes ici qui sont pas amis avec l'anglais...
oui ça serait appréciable ... merci d'avance ... :)
thepoete
Modele : Camaro SS cabrio BVM
Message par thepoete »
Bon, voici la traduction.
Innflutt í apríl 2009 sem '10 módel , fimmta Gen Camaro er nýjasti aðilinn á endurnýjuð ponycar stríð Big Three er. Þrátt seint að byrja bílsins, eru loyalists ekki taka aftur sæti til að einhver , þeir hafa verið að berja á bílum , finna hvað fer úrskeiðis , og beita gamla góða heitt festingar engineuity að ákveða málin en að gefa öðrum krakkar að hlaupa fyrir peningar þeirra . Enn , the nýr undirvagn enn verk í vinnslu . Búast Big úrbætur í efstu driveline gjafir fyrir '12 , en í millitíðinni , hér er borið á bílum eins og þeir eru nú stillt. Ráðgjafar okkar eru harður-algerlega Camaro sérfræðinga Lingenfelter Performance Engineering ( LPE ) , LIVERNOIS Motorsports , IPS Motorsports , School of Automotive Machinists ( SAM ) , og aðrir innherjar . Allir vitnað máttur stigum nema í birgðir verksmiðju einkunnir eru á afturhjólin . Mundu , það er að minnsta kosti 15 prósent tap í gegnum drivetrain með handbók trans , allt að 20 prósent með sjálfvirka .
vél
Fimmtu Gen Camaro Varahlutir Bilun Capital afrek : eins og af seint 2010 , Lingenfelter er Stout '10 Camaro hefur keyrt bestu Quart
6.2L ( 376CI ) LS3 (Manual Trans )
The LS3 er verksmiðju metinn á 426 hö og 420 lb- ft af togi fyrir handvirk trans bíla . Nú er þetta valinn greiða fyrir alvarleg uppfærslur árangur , eins og það hefur ekki breytilega camshaft tímasetningu ( forvarnarmóttöku ) eða virkt eldsneyti stjórnun ( AFM eða strokka valkosturinn er gerður óvirkur ) .
Lifter dæla upp ( 7000 plús rpm ) : Skipta skemmri ferðalög Comp Cams lifters sem þurfa annaðhvort stillanleg rockers eða vandlega völdum pushrod lengd .
Tímasetning keðja tensioner mistekst ( 550 hö ) : Setja upp Comp eða JP árangur billet tímasetning sett .
Oiling þarf hjálp (vegur - kappreiðar eða stroker vél) : LS vél olíu dælur framhjá of mikið olíu , auk léleg olíu holræsi aftur og freyði er alvarlegt vandamál á 6500 rpm . Fara á breyttri aftermarket oiling kerfi og pönnu . Fyrir vegum kappreiðar , íhuga á þurru sump .
Fimmta Gen Camaro Varahlutir Bilun Get ekki snúast þessi: Ekki búast við birgðir kólfurinn að endast í mikilli rpm eða með stór Strok
Stöfunum brjóta ( 600 hö) : Stock duftformi - málm stöfunum geta bilað geisla . Nota fölsuð stöfunum .
Head gasket vandamál ( 600 hestöfl ) : Uppfærsla til Aftermarket MLS þéttingar og ARP boltum.
Pistons mistakast ( 600-625 hö , detonation og / eða óhóflega uppörvun ) : Settu lager hypereutectics með fölsuð stimplum .
Sveif gott að fara ( 900 plús hestöfl ) : LPE Turbo vélar gera meira en 900 hö á lager nodular járn sveifar .
Útblástur lokar ( yfir 10 psi Boost ) : Á þessum tímapunkti , LPE skiptasamninga birgðir LS3 útblástur lokar með fleiri varanlegur Inconel eða natríum - fyllt sjálfur .
Eldsneyti kerfi uppfærsla ( Ýmsir miðlar) : Setja stærri injectors á 450-475 hö . Fyrir rúmlega 6 psi boost eða 500 hestöflum , nota spennu hvatamaður . Uppfærsla á lager púls-breidd - mótuð nonreturn eldsneyti dæla á 575-620 hö . LIVERNOIS og LPE hafa tvískiptur - PUMP SYSTEMS fullnægjandi gegnum 750-800 hestöflum . Umfram það að nota tveggja eða þriggja dælur hár -rúmtak og aftur - stíl eldsneyti kerfi .
Fimmtu Gen Camaro Varahlutir Bilun villst : Pushrod sveigju frá stórum kambás og aukin þrýsting vor orsakir
6.2L (376 CI ) L99 ( Auto Trans )
The 400hp/410-lb-ft L99 er notað í V8 Camaros með sjálfvirka . Með bæði forvarnarmóttöku og hollenskra yfirvalda að það er erfiðara að breyta í birgðir formi . Short- blokk vandamál eru svipuð LS3 .
AFM vandamál ( 450 hestöfl , 0,500 - tomma - lyfta kambás , eða hár rpm ): Helmingur lifters og samsvarandi kambur þeirra lobes eru einstök . Comp og LPE bjóða AFM - stíl kambás , en þeir eru takmörkuð við 0,500 -lyfta vegna þess að sérstök lifters virka ekki með minni stöð hring . Ef þú hækka REV limiter umfram 6200 - rpm Takmarka L99 og síðan keyrt upp gegn henni , Jannetty Racing segir afm lifters mun mistakast . Besti kosturinn : reprogram ekur að eyða FHB , þá setja upp hefðbundnum kambur og lifters .
VCT Phaser woes : Valve - til - stimpla samband getur átt sér stað með stærri kambás frá of mikið fyrirfram. Comp Cams hefur Phaser takmörk Kit sem gerir árásargjarn kambur snið með allt að 220 gráður lengd á 0,050 . Umfram þetta, annað hvort : auka neyslu center 2 gráður fyrir hverja 4 - gráðu lengd hækkun , breyta stimplum , eða eyða forvarnarmóttöku , en seinni krefst installing a LS3 framhliðina og hefðbundin tímasetning sett .
Loki fljóta : L99s hafa ekki holur - stofnfrumum inntaka lokar á LS3 er. Þegar skipt er hár - lyfta kambás , LPE mælir setja léttari LS3 inntaka lokar .
sending
Fimmtu Gen Camaro Varahlutir Bilun Break - hratt: The mainshaft á um 10 prósent af TR - 6060 -búin Camaros framleidd innan
6L80 Sex þrepa sjálfskipting
Þessi ný- Gen GM trans er svo háþróuð að það hefur sérstakan tölva (TCM eða sending stjórna mát ) . Vitlaust TCM Tuning veldur fleiri vandamál en harður- hluta mistök .
TCM kvörðun : endurforritun er krafist þegar breyta vél rpm svið , breyting stig , eða rearend gír hlutfall. Verulegur Power breyting eykur vél hröðun hlutfall , sem breytir magn trans miði , bæði áhrif þegar breyting þarf að eiga sér stað miðað við þegar TCM reiknar það ætti sér stað . HPTuners hefur endurforritun hugbúnaður.
TAPshift töf : Þegar virkjað , eru á-krafa Handbók breyting gír gerð með stýri paddles. TAPshift leyfi að halda sérstaka gír kringum vegum auðvitað án þess að óttast að trans gæti upshift eða downshift meðan á aftur og grafa bílinn. Það virkar líka vel fyrir Burnout , en inntak töf skapar með línulegri hröðun málefni , því að draga kappreiðar, reprogram að upshift sjálfkrafa á tilteknum vakt rpm .
Tog stjórnun skemmdir : Slekkur stjórnun togi alveg geta valdið mistök. LPE segir: " Með kúplingu - til - kúplingu trans eins og 6L80 , sumir tog stjórnun er þörf til að draga úr tog augnablik og leyfa tími fyrir kúplingu fyrir viðkomandi gír til að taka þátt . "
Togi breytir ( 500 plús hestöfl ) : LPE skýrslur núll bilun , IPS er fullviss um 500 hestöfl , og LIVERNOIS segir það hefur " lager breytir í '10 Camaro sem gerir yfir 750 hestöfl með nærri 100 kvartmílunni keyrir ásamt götu akstur . " Precision Industries , TCI , Yank , og aðrir selja hár - þæfa breytir. A þrefaldur - diskur breytir og sérsniðin trans Tuning mun tryggja breytir dvöl læst upp í Overdrive jafnvel á hár - máttur Mills.
Fimmtu Gen Camaro Varahlutir Bilun tannskemmdum : Misheppnuð vaktir geta skemmt Synchro blokka hringa og helstu - gír kúplingu - engag
Harður- hlutar mistök ( yfir 575 hö ): með réttri forritun, LIVERNOIS og aðrir skýrslu lágmarks innri harður -hluta mistök í gegnum 575-600 hestöflum . Rossler byggir eflt 6L80s . Það segir 3-5 andstæða kúplingu mistekst yfirleitt fyrst , á eftir 4-5-6 kúplingu : " Við bætum fleiri þrífur , vél sérstökum stál , og nota betri efni . " Fullu byggð Rossler 6L80s hafa staðist 1.000 hestöfl á undirvagni Dyno , 750 hö er raunsærri fyrir langtíma götu endingu .
TTC TR - 6060 Sex - gíra beinskipting
Eins stafur -Shift dodges og Shelby Mustang , V8 Camaros nota TTC TR - 6060 sex hraða . Virkjun GM ráðast stjórna lögun geta lágmarka líkur á trans eða rearend bilun . RPM Sendingar ' fullkomlega blueprinted Level 6 TR - 6060 ræð meira en 1000 hestöfl.
Mainshaft hlé ( af handahófi) : Á sumum snemma framleiðslu '10 Camaros er mainshaft getur mistekist undan framleiðsla splines vegna óhóflega stórum machining radíus. Þótt 475 hestafla er líklega mikilvægt áhætta lið , RPM segir það geta stundum "ekki bein lager, jafnvel með verksmiðju - upprunalegu dekk . " Festa GM er endurhannað chamfer , bæta bræðslu og annað hita skemmtun . Ný ' bol má retrofitted , en það þarf að ljúka tearDown . Tilvísun GM þjónusta bulletin PIP4666 .
Aftan stuðningslega uppfærsla ( 650-680 hö) : Ólíkt sumum öðrum TR- 6060s , Camaro útgáfa skortir aftan stuðningslega . The Camaro framlenging hús er fræst til að bera, en það er ekki verksmiðju sett upp. LIVERNOIS ráðleggur bæta áhrif yfir 650 hestöflum . Bera, auk betri 9310 - stál mainshaft gangsett fyrir það , er selt sem kit frá RPM Sendingar og The DRIVESHAFT Shop.
Synchro blokka hringur ( 525-625 hö og / eða misnotkun ) : Early framleiðslu hefur kopar hringjum, en síðar hefur koluð hringi. Kolefni er meira að fyrirgefa , en eir hringir eru sterkari ef þú ert heitur skór .
Kúpling vandamál ( 600 hestöfl ): Þótt SAM heldur að " bein - birgðir máttur mun taka kúplingu út hlaupandi á Sticky dekk - jafnvel draga geislamyndaður , " flestar aðrar heimildir segja alvarleg kúpling vandamál byrja í kringum 600hp til 650hp stigi . Uppfærsla sem við á aftermarket þrífur . LPE rekur þrefaldur diskur RPS kolefni kúplingu í 1240 hö draga bílinn hennar .
Vökva kúpling virkjunarbúnað málefni : IPS hefur séð mjúk kúpling þátttöku og erfitt með að fá bílinn í gír eftir mörgum framhjá dragstrip . Virðist hita aðdraganda veldur kúplingu vökva seigju sundurliðun. Blæðir kerfið oft og nota meiri gæði kúplingu vökva.
IRS og DRIVESHAFT
Fimmtu Gen Camaro Varahlutir Bilun sparkað í rass : Á þriðja dragstrip þess sjósetja gangi Hoosier slicks , þetta aftermarket
V8 Camaro er IRS ( sjálfstætt afturfjöðrun ) hefur 218mm ( 8,58 tommur) aftan gír og kúplingu -gerð takmörkuð - miði breyting. Gír eru einstök . Lager hlutföll eru 3.27 eða 3.45:1 ; Richmond hefur 3,70 og 4.10:1 hlutföll. Núverandi birgðir aftan er lélegur fyrir alvarlegum hár - perf notkun.
Afturfjöðrun beygja ( 450 hö) : IPS skýrslur tá -armur bilun sem lágu eins og 25 til 50 HP yfir lager. Pfadt hefur stiffeners ; BMR býður stillanleg einingar . Óþarfa wheelhop getur skemmt aftan slóð vopn , sem stuðla að mismunadrif vandamál ( Pfadt og LPE hafa uppfærslu). Hotchkis selur undirvagni Max Brace að stjórna óæskilegum fjöðrun hreyfingu .
Aftan subframe beygja ( 475 hö) : The Stock subframe bushings leyfa umfram vagga hreyfingu , sem veldur missti afl og slæmt grip . Skipta með föstu eða pólýúretan bushings fyrir betri aftan- vagga endingu og bættri meðhöndlun. Pfadt er ein uppspretta .
Gears mistakast ( 500 plús hestöfl ) : Aðeins þriggja röð vatnsfletinum flytjandi er í boði , þannig að Vængbroddur gets raunverulega lítill eins gírhlutfalli eykst. Hjólbarða og akstur stíl áhrif langlífi toppurinn .
Halfshafts brjóta ( wheelhop , 500-600 hö ) : The alvarlegri sem wheelhop , því fyrr sem aka ása brjóta . The Stock tölva kvörðun marka axlehop , en einnig marka árangur . Vitandi hvenær á að koma sér í burtu úr inngjöf er ódýr festa , eftir léttari hjól og dekk ( vegna þess að þeir hafa minni tregðu ) , og að lokum stouter aftermarket ása .
Vatnsfletinum vandamál ( Ýmsir miðlar) : Jannetty segir birgðir vatnsfletinum er veikt : " . Það er viðkvæmt fyrir einn - legger burnouts , en Breakaway togi er alltof lágt" Vatnsfletinum mods þess eru uppfærsla Clutch bakpoki og aðra Forhlaða vor . Með lag vatnsfletinum og endurskoðaðar gír preload , úthreinsun , og mynstur , stofninn aftan getur tekið allt að 750 hestöflum , en 650 hö er raunsærri fyrir daglega akstur .
DRIVESHAFT mál ( yfir 5000 rpm) : Flestir skýrslu sem birgðir tvö stykki DRIVESHAFT er furðu sterkur . 9 sekúndna Camaro LPE notar stytta , lager, tveir- stykki " bol , en með betri miðju stuðning til að koma í veg miðju renna vindist og bindandi . Hins vegar DRIVESHAFT Shop heldur að " nokkuð með a renna er óstöðug yfir 5000 - rpm DRIVESHAFT hraða. " Lausnir sínar allt frá stouter tvískipta eining með CV liðum eða a einn - stykki ál eða kolefni - fiber " bol .
Bon, ok en Islandais, mais c'est plus joli tous ces symboles non? ^^
:redass:
Vic
Message par Vic »
:LOL: :LOL: :LOL:
ça peut être utile un jour... :grin: si on a un nouveau membre Islandais :o je ne sais même pas si la Camaro est présente là-bas.
thepoete
RDesign a écrit :ça peut être utile un jour... :grin: si on a un nouveau membre Islandais :o je ne sais même pas si la Camaro est présente là-bas.
Faire des burns dans les paysages désertiques lunaires des abords des volcans, ça doit être géant !!
Surtout en cabrio ^^
Sépafo ! quand prendras tu un billet d'avion cargo à destination d'Islande ? :grin:
